1 - 10 of 10 Posts
Help I need to know where the location of the day time running lights module on a 2001 Ram is as I need to install it for import into Canada?
Help
Thanks
You can go to the dealer and buy the relay for DRL but only if you have a truck with the right main harness in it (i.e. Canadian trucks), otherwise you have to wire one up yourself. I believe all of the trucks that went to Canada have the correct harness. Most aftermarket modules will not work on the truck either because the headlights on the truck are negative switched. With the lights off check all three wires on the lamp with a test light and you will find that all three wires have power and if you ground one of them out the lights will turn on. I wanted to have DRL's on my '99 and all I did was use a relay to provide a ground on the lowbeam wire and powered the relay off an ignition feed. All you need to do is tap into one side and both of them will work.
hmmmmmmm
hay thanks but I figured it all out today and I have the wrong harness for the factory module but I had crappy tire do it for me today while they were doing the inspection.
Thanks
Any body need a cheap module?never used
would you have a picture on how you wired this up? i have to do our 01 for riv inspection
they want the fact lights to light,guy is a a$$
anyone got a picture how to wire the relay up? gotta get this working
Are the '05's different than the '08 ?:confused013:
I know on mine the DTR lights can be activated by starscan. Have to set the vehicle to "export" in the settings then you can activate DTR, Fogs w/ High beams etc.
star scan will do the newer ones this is a 02 i goota rig it up my self
1 - 10 of 10 Posts
