Other night turn lights on and my dashlights dont work.I checked a fuse fir illum. not burnt out.didnt check anything else yet.What could it be,bulb burn out.
Blinker and high beam lights still come on.Just no background light for the cluster.
On call 24/7
Its gotta be a short or a fuse. If you hit the dash will it work? Check the under hood fuses too.
might be the rheostat in the switch also, try twisting it back and forth ans see if ya get em to flutter on and off
checked all the fuses and everything checked out good.Turned it a bunch and still nothing??????????
Hard to drive at night.
Check the wiring to the radio, yellow wire on mine came loose and caused the same problem. Only a 700 buck fix at a dodge dealer
