So my original dash has about had it. Ive seen some trucks with dash caps that dont fit good and look like S***. But a complete new dash is pricey. Can anyone tell me the pros and cons of both? And which ones are good? Ive seen LMC's and they claim to have a UV protected plastic to prevent cracking...
Also need a new radio bezel.
Thanks!
I would do it right the first time and be done with it.
full replacement dash from LMC truck.
have a buddy that did his with an LMC dash and he loves it :thumbsup:
the caps make your dash taller, its painfully obvious its there, and its not going to stop the dash under it from making noise and falling apart even more...you might as well just throw a mat over it if you're thinking of capping it...
that is the dash cap i installed. i am very happy with it, and my attention to detail is borderline OCD. Once you install it, your passangers will never notice it is a cover. Also, I Highly recommend having them color match it for you. You'll need to check your doorjam to see what your trim code is, and they can match the color. i would rate my cover, the fit, color match, everything..at 95%.
PA VICE PRESIDENT
