About to burn this truck to the ground. This code has been happening since last year. Didn't pay much attention to it since it had only done it twice last years when the temps were under 20 degrees. Figured it had to do with the cold snaps. Well now its been doing it frequently now for the past month. Had the check engine light come on with the flashing lightening bolt flashing. Did it as the truck was warming up. did it while driving, though there might of been a sweet spot in the pedal that might be causing it but it wasn't since its done it while sitting at a stop light. Did it one time as I was backing into a parking spot, did it as I was hitting the breaks to make a turn. Though turn the truck off and turn it back on and it's fine. Did a search on here and decided to check the wiring for any type of rubbing. Nothing. Cleaned the connector at the pedal just to see if that was it and nothing. I read where some were changing the pedal out but that didn't fix there problem so I haven't tried that yet. Don't want to by one and that not fix it. Was going to look more into the brake pedal since it happened twice when I was pressing the pedal but then it's happened when I was pressing the accelerator pedal also. Anyone might have any other suggestion on where I might start checking, I might of missed something.
