Hey guys. Trying to figure out a good twin setup for my build, the goal is around 600hp with a quick spool while getting the big air for the top end.
It will be 85% daily driving and 15% towing/play on the streets
The bottom end is being rebuilt to 0km with stock everything
as for mods the list is this(still flushing exact details out at this point):
024 DV's
90hp injectors
benchflowed/tuned pump
colt big stick cam
hamilton pushrods
120# springs
4gsk
Studs
water/meth
o-ring/fire ring (getting conflicting info on which is best for street use)
essentially it will be an overbuilt engine, just need a good setup to run after the break-in is complete on the stock fuel/air
Will a ported hx35 be a good canidate for the high pressure? or should a s300 frame be use with a s400 as secondary on either turbo
Thanks for the help and ask for anything you feel I've left out
024 DV's
90hp injectors
colt big stick cam
hamilton pushrods
120# springs
4gsk
Studs
water/meth
