Time to pick your brains a bit...
I've been working on figuring out the Cummins programming for a while, and now that I've figured out enough to be able to start tuning my own truck, I'd like to see how much interest there is in a system that would allow you to do your own modifications to the truck's programming. This would be similar to the EFILive stuff the Duramax crowd has, but limited by the capabilities of the vp44 - I don't think there is any more horsepower available than any other product out there that does not tap the pump wire.
In its simplest form, the product could consist of the editor software, the download software, and the USB cable to connect the PC/laptop to the truck's OBD connector.
A more complex approach would be to create a handheld 'box' that you transfer your custom file to, and the box would plug into the OBD connector to download the file to the truck.
Please be aware that this setup would ONLY be for engine tuning, it is not capable of doing anything in the PCM (ABS, tire size, etc.)
Thoughts? Suggestions?
