1 - 20 of 20 Posts
Ever since I've went the Pulse I've missed my mechanical gauges, so this is what I came up with.
Now I have the best of both worlds and the abilty to monitor 6 different parameters at once.
so now back to a questionn i asked way back. how close are the mech. gauge readings to the pulse readings?
Banned
better pics? I'd like more knowledge on this setup, I'd like to run a mechanical boost gauge and fuel pressure gauge.
Discussion Starter · #7 · (Edited)
I was waiting for this question. So far it appears the Pulse reads EGT's higher then the Di-Pricol guage (Depeding on the temp it can be anywhere from 50 to 100+ degrees). Still doing some R&D. The boost readings seem to be pretty close (within 1 or 2#).
As for what it took to make this pod, 1 ea. Pulse full pillar and 1 ea. 2 guage pod secured with the 'plastic rivets'. I'm not good at fiberglass, but if one were, I'm sure they could make this pillar look as if it were one piece.
GOOD INFO thankyou the one i really wanted to know was fuel pressure if you have fuel on your pulse
Discussion Starter · #9 ·
I do have fuel pressure on my Pulse and it reads as accurate as a mechanical gauge.
awsome i feel better now knowing its a pretty acurate setup thanks again for the info
Just Another Slow VP
looks good!:thumbsup:
ive been wantin to do the same with edge attitude and a few reg. gauges:party018:
Discussion Starter · #12 ·
I've found the EGT on the Pulse reads similiar when you adjust the "EGT Adjustment" on the Pulse to level 3.
Banned
What exactly does that "EGT adjustment" do anyways?
my guess was that it was to callabrate the pulse which is why i was asking him about the accuracy. it should be close right out the box
Looks like he customizes well. What is this Pulse I googled it and got nothing. I know Edge is coming out with a reader without having to install their chip soon. How much is this Pulse and where you get one?
its an added piece for the quadzilla adrenaline it lets u do custome tunes and monitor your truck. i think they have a stand alone unit but i wouldn't recomend it you can check out all their goodies at Quadzilla Performance - Home
Reactions: Dieselnooby
Their standalone unit is called the scout. It's only 65hp but is supposedly able to be custom tuned as well as reading parameters similar to the adr/pulse combo.
Discussion Starter · #18 ·
This is correct, it actually changes what the display reads. Say idling, you see 300*, if you change the "EGT adjustment" either higher or lower the reading on the display will change accordingly.
Dusting this thread off. You still got this pillar pod? Im gunna make one and wanted a few more pics if you could.
President of the 509
It's not that hard to do. I'd suggest mounting the pillar for the pulse/scout first, then marking where you want to mount to two gauge pod on it. I glued mine together and it seems pretty solid. You will have to drill holes through the pulse pillar cover for wires
1 - 20 of 20 Posts
