As many know I have just finished my project. I was wondering if I needed to have hoses made to have my dodge ac compressor hook to the ford condensor or will the hook right up?
Thanks
I would shoot an email to destroked.com, they should be able to take care of you
Joel's Diesel
I took the old ford lines into carquest and had them extend the high pressure line about 18 inches, to a 8AN flare fitting to the 90 degree ford steel line on the driver side before the pressure switch. Then I took the big low pressure line, cut the ford line down a bit, cut the end off of the dodge line, and had them crimp on a 12an hose\fitting to both lines(I think thats right, can't remember). Could be AN, could be JIC. bolt it up, oil it, fill it, works great.
http://i279.photobucket.com/albums/kk150/icemanjc1/DSC00924.jpg
http://i279.photobucket.com/albums/kk150/icemanjc1/DSC00925.jpg
http://i279.photobucket.com/albums/kk150/icemanjc1/DSC00926.jpg
http://i279.photobucket.com/albums/kk150/icemanjc1/DSC00927-1.jpg
Joel's Diesel
Also, you might have to notch the front crossmember for the compressor.
right on, Im going to have a local company make me some mix and match lines and hook her all up and give her a go.
