1 - 9 of 9 Posts
Rescue Tower
sure do. you want to provide some specifics on your project?
Dana 80 with 5:13 gears busted teeth off ring gear, any opinions if I should get my new set cryo treated.
2.8 turbo tuned and tweaked smokes a little
I was just referred to Home - 300 Below, Inc. today i plan on cryo treating my input shaft when it comes in
They go $3.50/lb with a $100 Min charge
Rescue Tower
Interesting. What were you doing when they broke? Typically the ring and pinion are strong. Spider gears may grenade subsequently ruining the ring and pinion though.
I'm not sure I would cryo a ring and pinion. I'll have to think about it.
I'm not to far away from 300 Below, that's were I planning on sending them along with axle shafts!
Well hooked on to sled, and you catch on quick!!! No spider gears, full spool.
The old shafts had been treated also, twisted both ends about a spline!!!
Rescue Tower
I figured you must be hooking up to sleds with that ratio. Well as deep into is as you are I say go for it. Whats the worst that can happen? You break a ring and pinion? Twist an axle? You've already been there. I'm assuming you are using quality parts? What kind of U-joints are you using? I figured they would break before the ring or axles. Good luck with it. Post some pics of the carnage. We always like to see the train wreck! :lol4:
Discussion Starter · #9 ·
Really didn't think it was that bad, seen a lot worse considering had 20-25 hooks on it.
It only took the outer half off the ring gear, pinion was actually unharmed!
Wouldn't have found any of it if outer axle seals were not leaking!!!!!!!
Wasn't sure if the cryo was the cause or not!
Done sent axles off for replacement and running 1480 yokes!
Tow rig 07 2500 Quad Cab 5.9 Juice w/ attitude
Puller 94 2500 5.9 2.8 turbo tweaked n tuned smokes a little
1 - 9 of 9 Posts
