I want to replace my cross over battery cable between the batteries. Seems pretty streight forward job. Where would you suggest I ger the cable? Napa? Is it a simple swap out procedure? Do I need to disconnect all the battery cables when I do it? Thanks?
I did a ford diesel one time and just got 2 0 gauge cables that were sized right and put the lug from the cable on the passenger side, under the bolt on the driver size cable that went to the starter.
with any battery removal ALWAYS remove the negative cable first (on both batterys) then remove the positive cable.
when hooking back up ALWAYS hook the negative cables back up last
On call 24/7
I got 1 O from the welding store and had them put ends on for me.
