I was looking around and most guys were venting there crankcase over the enginge to exit behind the transfer case. I was worried about it freezing any moisture in the line (It gets right down into the negatives here) and causing major problems so I just flipped the hose thats on it around and mounted the breahter bottle on an existing bolt higher up and got a 4 inch piece of plastic pipe to extend it into the bottle so far so good it just barely clears the hood and now the line is higher than the oil level would ever think about being. Hope this helps.
