im not sure if its original or not. i got a brand new replacement and it looks the exact same as the old one. Theres a spring loaded piece on the roller and i dont know how to keep the spring preloaded to a point where i can bolt the new motor in?:confused013:
Window Regulator
REMOVAL
Lower window to full down position.
Remove trim panel and watershield.
On stereo equipped vehicles remove lower trim panel and remove speaker.
Remove vent wing.
Slide glass forward off of regulator arms and lower glass to door bottom.
Drill out regulator mounting rivets and remove regulator through access hole.
INSTALLATION
Insert upper regulator arm into door mounted channel.
Mount regulator to door panel with 1/4-20 screws and nuts torqued to 90 in. lbs. (10 Nm) .
Slide glass onto regulator arms and into rear glass run.
Install and adjust vent wing.
Raise glass to full up position.
Install stereo speaker (if so equipped).
Install trim panel and watershield.
Is this what you are looking for? Its from my Alldatadiy account.
