2001 Dodge 2500 diesel started then died ansd now wont crank. Occassionally it had been bogging down when you first start up and drive off. It would either recover or stop and kill engine and restart and it would correct it self. I have replaced the fuel filter and I plan to check it with a code reader. A friend has a 99 model that had the same problem and they replaced the crankshaft position sensor. What codes are the crankshaft position sensor and the camshaft position sensor? I plan to check for fuel flow to verify if lift pump is working properly. When I turn key on lift pump chirps, but it hasnt filled the filter reservoir. Very limited in knowledge of diesel engines.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Cummins Diesel Forum
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
