is it possible to delete or bypass the crank position sensor on a 99' ?
thanks
thanks
:confused013:real question is why? Another case of the wrong motor bought?
Same here my 2002 only have the cam sensor. This is the exact same wire that the crank wire use though... Look and see for yourself.Might want to check that guys... I think mine only has a cam sensor right by the VP.
This post said otherwise... Just a little confusing! :thumbsup::confused013:
All 98.5 to 02 engines all have a crank sensor just depends in what year where it was placed. Early was on the crank above the starter and the later was on the gear case for the cam. It was the cam sensor that was no longer use in the later series. But crank sensor is mandatory equipment.
Yea its a bit confusing in text...This post said otherwise... Just a little confusing! :thumbsup:
Because the PSG is programmed with basic information to fire up and idle (or high idle). But that's it all other functions come from the ECM.What i do not understand -the pump can be "hot wired " (no sensor input and our trks will start and idle.)
No input from any sensor.
I find that not logical, but i have done it looking for the bad VP44 as per (blue chip)
Hence the P1690 code...The ECM compares the cam/crank sensor to the tone wheel in the VP44. If not correct, it will be in limp mode.
Ed
