1 - 4 of 4 Posts
So i finished installing my AFE megacannon intake on my 08 CTD 6.7. And the friggin crank case intake tube is not long enough to plug back into the AFE intake. Should I just get a longer tube from the store? Also even if it was long enough it looks like it just sits in the hole of the intake. It doesnt secure in there very well. It looks like it would just pop in there and thats it. Any body know what i should do with this tube vent???? Truck is parked till I can get this fixed!! thanks
It's all emissions related. As you know the EPA got strict... bla, bla, bla.
Just plug it where it should go. Just make sure that the turbo doesn't suck it in. Does it come from the valve cover? If so try securing it there. Hope this helps.
So i should just plug this tube and then plug the hole in the intake?
No. This would probably build high crankcase gas build-up. Will probably blow some kind of gasket. Just buy new hose and stick it where is supossed to go.
1 - 4 of 4 Posts
