My clutch support plate is cracked.
Can I remove this bracket without removing the dash?
Looks like theres some sort of holding nut on the si
de of the rod where the brake attaches, meanwhile on the clutch side, there's no pin and the bar can slide back and forth, is that normal?
Or am I missing a holding nut on the clutch side...
I'll Probbaly have to weld it back together, anyone else with the same issue?
