Hey guys, couple quick questions.
I recently replaced my IP and haven't tapped the wire for my edge comp yet. I was wondering with it not tapped does it still provide the timing advance or is the tap required? Also I noticed when I was playin with WOT that I almost drove it into the red zone on my rpm's before I backed off, does this mean it's got the drag unlock on it? I thought the stock defueled at 2700 but I was surely around the 3200 I heard the drag fuel to. I'm just curious since it doesn't say anything about drag on the box itself.
Also even with it untapped I can make 30+ psi pretty easily and smoke with the box off now that the new pump is on, do you think I could have aftermarket injectors/nozzles? I've checked all the boots and even pressure tested it and nothing leaked. Kinda curious and hopeful.
Thanks for your help! :thumbsup:
