1 - 10 of 10 Posts
No.
No. No. No.
You can even see how heinous the threads are on their stock photo. No.
Dont do it.
Unless someone feels like taking a huge gamble here. Which I doubt any of us would do. You included.
Someone needs to report them to arp they even used the same part number!!!! In all reality if someone was to be a test subject would be interested to see how well they work. My money is on they are garbage though.
The Uppity 12v Admin
You get the torque wrench, I'll get the popcorn.
I tested a $300 set of ARP knockoffs and they were garbage. Washers started squishing out from underneath the nut at 90 ft-lbs. With ARP washers, the studs yielded at 130 ft-lbs.
These ones you linked look even crustier than those ones I tested.
C'mon guys they are "Grade steel construction"....
Like this?
These washers came with the SHCS head bolts I used in my engine.
Washers started crushing around 100 ft-lbs
I stopped at 120 ft-lbs after installing ARP washers
Like this?
I guess the guys who put that kit together have never heard of hardened SAE washers?
1 - 10 of 10 Posts
