All the research I've done indicates the correct P/N as 3944833, but when I went to Cummins they gave me a set of 3936453 for my 2002 HO. Did the second number supersede the first? I've seen both listed for 1998-2002 so I can only assume they are interchangeable. Is there any PHYSICAL difference between each, i.e. internal diameter? Thx
what I was told was the newer connector tubes are a little larger inside diameter and work fine on all the second gens. I believe it is the same ones used on the third gens. Just verify with Cummins to be sure.
I spoke to Cummins Parts Dept today and found out that 3936953 is an assembly P/N, which includes Connector Tube 3944833, and O-Ring 387043. No difference in any parts. Hope this helps
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Cummins Diesel Forum
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
