I've run Coopers on many trucks for over 15 years. I've had nothing but good luck with them. I'm currently running the STT tires in 315/75R16.
-Chuck
-Chuck
Hey Chuck, what are the lift specs on your truck? Or is it just a leveling kit?I've run Coopers on many trucks for over 15 years. I've had nothing but good luck with them. I'm currently running the STT tires in 315/75R16.
-Chuck
Well I have a 2" or 3" leveling kit and mine looks tall, but not that tall. Would you say you're about 4" over stock?It is a 2002 2500HD. It has the heavier plow coil springs up front, camper springs in the rear, and a Dana 80. Then I added a 2" front leveling kit, Timbren overloads in the rear, Moog trackbar. That's basically it.
-Chuck
check out my truck pics...same tire size from Discount Tire.im looking for a set in 325-60 r18 if anyone knows where i can get some
What kind of mileage have you seen out of this tire?I've run Coopers on many trucks for over 15 years. I've had nothing but good luck with them. I'm currently running the STT tires in 315/75R16.
-Chuck
