1 - 2 of 2 Posts
i put a fan clutch on in dec 10,(it was making a vibaritation niose). yesterday feb 1, it started again. my repair manual says not to loosen the cooling fan pulley bolts, that it is under spring tension. are their bearings in behind this pulley?, could this be why my clutch lasted only 1 month?, can i change this pulley or bearing?. (or did i just get a bad fan clutch and need to replace it again)i use my truck daily to make my living, help. 346,000 miles.
thanks for any help
Discussion Starter #2
yep it sure does have a bearing,,,list 245.00 at local dealer, bought it under body shop name at dealer, and 187.50 out the door. it is a big sucker, had to press it out and in, now ready for another 346,000.....
1 - 2 of 2 Posts
