LOL! Well buddy, your really not that bad off. You can replace that o-ring with any small 0-ring you can find. Go to your local auto parts store and get one. Just unscrew the pet-**** untill it comes out. No you don't have to replace the engine plugs. No the dealership won't deliver to your house only to a buisness. You have 9 gal of fluid, and 4 of that you won't need. Out of a 7 gal system you will only get a max of 5 gal out. My best suggestion is to get a new water pump too. They are way easy to replace and supper cheap. The belt is the hardest part. You will need a extra set of hands. Now that I think of it some petcocks don't have a rubber ring. Its normal for it to leak out the threads when you unscrew it too far. Just take it all the way out. Its a faster drain that way. Then when done just tighten it back down finger tight. You should have no leaks. Good luck.
