1 - 9 of 9 Posts
My 2002 6.9 4 wheel drive 4.11 gears auto runs fine, but it seems that the converter or the overdrive kicks in and out between 40-45 mph a friend told me to clean the ground wires where the bolt to the Body. I found three small ground wires cleaned them with sandpaper and re tightened them it seamed to help for a short time. Any suggestions how to resolve this issue?
clean your battery terminals too. also check and see how tight your clamps are on your post. another thing is have your batteries checked to see if one is bad. if nothing from there then have your alternator checked as well.
almost every time mine comes back there is something else wrong with the truck. you can trace it back to the problem area most of the time. my last time i had a bad battery.....well 2. any little bad connection will cause a problem. the filter aids in giving a better signal. you may and may not need it.
I cleaned all my grounds really well and did an apps re wire at the same time and havent' gotten it back again... don't have the link anymore but im sure somebody out there does... been gone for a couple months now :) lets hope it all holds out
1 - 9 of 9 Posts
