1 - 20 of 24 Posts
I had a buddy with a 7.3 PSD and he put a toggle switch to lock his converter up. my question is do the make a "something" to do that, on the 68rfe? Can it be done? would it help save your tranny? hurt it?
Does the tow/haul mode switch have anything to do with that.
I dont know does the tow/haul mode lock the converter faster?
I'm not sure. I know on my 2000 Durango if you leave the OD off switch on then I has something to do with the torque converter lockup. Don't know if the tow/haul has anything to do with it or if it just holds the gear longer to keep the power up if you are towing a trailer or have a load.
Banned
To be honest i really dont notice any difference with tow mode on or off when accelerating and cruising speeds. Only time i notice a difference is when slowing down. i would really like to see a lock up though made for these trucks.
I know mine will hold a gear a little longer as it goes up through the gears when accelerating with tow/haul on. I don't know if it does it at lower throttle inputs. I usually notice it more when I am on the throttle more.
but what i was getting at is there has to be two wires you can put a toggle in between to lock it up ? just need to find out what wires they are????
Banned
Is this towing or unloaded. cause when im towing heavy, either way the tow mode is set, sometimes i have to ease off the throttle for it to shift gears. this is a nice tranny, but really does need some tweaking.
Banned
Get to work, im waiting!!!!:lol3:
:popcorn::popcorn::popcorn:
Discussion Starter · #10 ·
for both. but more for when you lay down on it it doesnt slip, <as bad> i want it to go .lol
Banned
the tow/haul mode just locks the converter up sooner so it doesnt slip it while towing
Discussion Starter · #14 ·
i just mesgd. my buddy to see what he did to his PSD ... maybe that will shed some light...
I couldn't find it either. I wonder if increasing line pressure would help.Hopfully someone comes out with a programmer or box to fix this.
MSD makes a switch control box. It's for nitous or electric fans, I think it could work good for a converter lockup box. It has a relay that is triggered by a signal from a sensor, TPS, VSS, coolant temp sensor. You calibrate the box to the sensor you are using as a trigger, then you can set what % the relay clicks on and % it clicks off. We could use the VSS for the trigger. The box also has a fooler wire for the ecu so it won't throw a code.MSD Smart Switch, PN 8966. Now we just need to know which wires are for the converter clutch and vehicle speed sensor.
Mine just holds the gear longer when I'm in tow/haul mode, no matter if I'm loaded or not. Usually it seems like it shifts around 2500 rpm, but it runs up to around 3000 rpm when in tow/haul. Either way, I only see about 30 psi max. I know if you manually shift, it will let you get up to about 3500 rpm before it starts dropping you down for hitting redline.
I did some digging in the service manual and found that the TCC is contolled by the L/R solenoid, and the solenoid is controlled by the PCM. The PCM grounds the DG/WT wire from the transmission solenoid assembely connector to lock the TCC according to the wiring diagram. I also found that the solenoid has multiple duty cycles to partially lock the TCC for a few seconds before it fully locks. This is the slipping we notice. I'm not sure if grounding that wire with a toggle switch would fully lock the TCC right away or not. I also found that the PCM controls line pressure from the signal from the line pressure sensor. The voltage supply to the sensor is 5 volts, the signal to the pcm has to be between .35 and 4.75 v to not throw any codes. I wonder if we could put a diode in the cuircit to raise the line pressure a little. Some one tell me how to put a picture on here and I will post some wiring diagrams.
Banned
Good job doing the research. I know when i first bought my trucks they tsb my tranny with a flash for low line pressure. What we need is a dang proggy that will do it. Doesnt sound like a hard program to make.
Image hosting, free photo sharing & video sharing at Photobucket to post pics
1 - 20 of 24 Posts
