In case my signature didn't post, I have a stock 97 3500 dually 2WD with Independent front suspension. I don't know how to remove the bushings from the upper control arms. You can use a press on the lower arms but the upper ones have the pivot bar in place making it impossible to access the bushings to pull them out. I suppose you could modify a ball joint press by cutting out part of it to slip over the pivot bar but maybe there is a better (easier) way. I have searched the forum with no luck and the procedure is not shown in my factory manual. Any help would be appreciated.
