So my fog lights have quit working and after learning you need a starscan tool to reset them I went an asked a local shop where I've had some stuff done if they had one. They didn't have one but he told me to try an take the battery cables off and touch the leads together and it would discharge the computer and reset once the batteries are reconnected and might save some money.
So has anybody heard of this or done it? I'm kind of leery to try it cause I don't know what it would do to my efi. I'm guessing if it worked I would just have to load the tunes in again.
Sometimes the battery lead trick will work but not always. I've had a few trucks with this problem, if you can find someone with the star scan tool it litterally takes about 3 minutes. Downside is most shops will charge you for a diagnostic or whatever.. but if you know anybody that has the tool it is super simple to reset. Maybe try disconnecting both batteries overnight and see what happens?
Sent from AutoGuide.com App
Have you checked fuses 15 and f25, is there corrosion? If they are good what you can try is disconnect your batter cables. Remove fuses f15 and 25, touch the cables together for about 30min, hook up the cables and then insert the fuses.
F25 I believe controls the relay for the foglights, you also might be able to check to see if there is any power on that circuit.
No I checked the book an it didn't show any fuses for the fogs or headlights even asked in here an didn't get an answer. Have to check those out
Book says 15 is trailer park lamps and 25 is power mirror
