1 - 3 of 3 Posts
So after a ton of measurements it doesn't look like I will be able to put my 64 body on the 99 frame:CRY: Now I am weighing my other options. My big question is if I want to pull the 24 valve out of the 99 what computer/electronics have to go with it and where they are located under the hood/dash. From what I've read there's a ton, but I just want to know the bare minimum I guess. thanks, andrew
It really depends on what you want to use it for. I would get all sensors, the ECM, PCM and complete wiring harnesses. To include transmission and engine compartment. Along with real wheel sensors and front wheel sensors. If you do not get a sensor, and need it later you will :CRY: regret it and shell out :$::$: , This is really one place where more is better.
1 - 3 of 3 Posts
