1 - 20 of 22 Posts
I want to delete the egr but I also want the egr cooler gone. It seems pretty stupid to put all that load on the cooling system cooling hot exhaust for no reason.
I saw one thread that had a picture of a C&C with the egr cooler gone, very nice.
Has anyone done this successfully on a standard truck?
Have not done it yet. Shouldnt be very hard to do though. You will need 2 blocker plates along with a piece of hose to bypass the EGR cooler. Other then that you should be able to just unplug it, remove it and be done with it.
Does anyone have a blow up pic of the exhaust cooler and manifold? I want to remove the exhaust cooler also. I was not aware that there are two block off plates needed.
I have new gaskets and metal already to build my egr block off kit. Now I just need a bit more info to remove the exhaust cooler side of the egr system.
Does the new manifold simplify the egr cooler removal? Seems there would be no blocking plates needed. Will a new manifold connect to the turbo OK?
it fits the head but wont bolt up to the turbo
I was curious of that. The Truck PDI built has the 5.9 manifold but not the VGT. thanks Matt.
Rockwerx:
There is 2 ports that it connects to the exhaust manifold. One near the front and the other all the way to the rear.
I took everything off to the manifold. Waiting for exhaust from BADP and MP-8 from K2 I already have Edge on hopefully it will all work. My truck is a 07.5 4x4 dually I would like to put in truck pulls. Looking for more to stack and water meth, propane, or nitrous.
throw the bullydog on there and upgrade the fuel pump to a Fass or AIRDOG. You will need the fuel.
I think a clutch also what bullydog, Power pup
Is that what you are running and did you get to a dyno yet? If all my parts come in time, they have dyno days here on the 6th at K&S Diesel.
I only run the 2 chips but i tried a Bully Dog Power Pup (Thanks Kevin) with it last weekend. It was crazy. I am getting on the dyno at the end of the month.
Rockwerx:
Thanks for the info. I was only aware of the rear exhaust port on the eger cooler. My parts guy did not mention the second port. Do you know if the front port is the same size as the rear port? I ordered a gasket for the rear port. I just wanted to have a plate/plates and gaskets made up in case those parts fell off!
I believe they are the same. I havent gotten around to pulling mine off just yet.
haha comcowboy, this is what I was talking about earlier...we need these guys to build this kit for us, at a good price, everyone would be set then.
1 - 20 of 22 Posts
