1 - 2 of 2 Posts
when you push in your odometer with the key off and then while pushing in turn on the key it will check the indash gagues for shorts while doing this i got the numbers {999} in the odometer slot. What does this code mean
Mopar1973Man.Com
Here you go... The write up for console testing...
Cluster Testing
999 means erro has been discovered press the trip button to continue... Record the error code...:w:
1 - 2 of 2 Posts
