No vehicle speed- could that be from the BD rad box?
And the 12 volt could that be from the torque converter lock?
And I have no idea what the rest are.
Po500- The code could be thrown by simple spinning your tires. Is your abs or brake light staying on?
P1693 is a companion code, telling you that there is more codes stored on the ecm.
P1694 is telling you that the ecm is not communicating pcm.
Im not sure about the p1765, and Po500 could be thrown because of the rad box.
No abs or brake light. Only light that stays on is my air bag. Are these anything I should worry about?
