1 - 10 of 10 Posts
Alright, on Saturday the 21st I changed my lift pump and put on a Holley Blue. It has been running excellent ever since, smoother, sounds better all together drives way better.
Today I started it at about 300 and got home around 345. I got my new Dr. Performance chip in today so naturally went to put it on (if you are not aware it attaches to the VP 44.
Now after I get it on my truck will not start, cracked the 1st injector line and got fuel, but never did any other ones.
MY truck is throwing up 3 codes,
P 1689
P 0230
P 1693
Any ideas?
P 1689
P 0230
P 1693
Any ideas?
p 0230 is the lift pump circuit is out of range, p 1689 is no cuminication between the ecm and vp44, 1693 is a code that pops up when there is a code in the copanion module, Did you do a wire tap if so maybe you cut the wire in half, or maybe tapped the wrong one, just check over all your connections. Or take your chip off and then try it. Check your wiring for your lift pump also.
Yes I did a wire tap, and ended up taking it all the way off and the whole chip and progammer are off and the truck still is not starting, still throwing those 3 codes after I reset them.
is the lift pump even turning on? Check your plug to the vp44 , that code p1689 says there is no cummunication to the ecm, if there is no power to the pump the truck won't fire, I don't know something happend somewhere..:confused013:
yeh the lp is clearly turning on and running, you can here it just fine. Yeah I am nervous the VP died, but would fuel still be coming out of the 1st injection line if it did die?
yep it would......... Laramie, Wyoming, I lived there for 10 months when I was going to good ole Wyotech, graduated in june of 07
F M L
over and over again
Discussion Starter #8
If I had put the Dr. P on the wrong wire going into the VP 44 would that have fried the pump?
Discussion Starter #9
bump Anybody got some more ideas on what is possibly wrong.
cumminsforum.com
1 - 10 of 10 Posts
