1 - 12 of 12 Posts
anyone know what code P1693 means
Mopar1973Man.Com
Simple!
There is 2 computers on these trucks ECM (Engine Control Module) and PCM (Powertrain Control Module). When one or both modules get a error it will put a P1693 in the opposite controller to notify you that the other module has a problem.
So basically all it means is that either one or both modules have error codes...:w:
so a manual transmission truck has a pcm???
Mopar1973Man.Com
Yes sir... It does... The PCM controls several other sub systems like your gauge cluster, torque management (1st and 2nd gear on a manual trans), etc... It mounted on the firewall behind the air filter box on the passenger side...:w:
ahh ok...I understand...so this code could be because of another code...I got a code for the crank sensor...yesterday...but CEL went out..I'm changing the sensor today..
Mopar1973Man.Com
There is a bunch of conditions the computer must follow to shut off the CEL or erase error codes... The rest of the information is here...
OBD II Error Codes
thanks bunch....explains many things..changed CSPS and all is good..
just installed a quad adrenaline and i now have the following codes 0500,1693,0522,0237 i know that the 0522 is the oil pressure sending unit and that the 0237 is most likley form the smoke switch but not sure. but why would the 0500 be there i have never had this code before i had the programer is this from the quad. any help on making all these codes dissapear would be great.
which code did he get
the 1693 code means that there is a code in both the computers. but what does the 0500 code from?
1 - 12 of 12 Posts
