1 - 3 of 3 Posts
new injectors
new injection pump
p036 what does this code mean??
u2269 what does this code mean??
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance What causes this, been getting it a lot lately!
Getting the lighting bolt a lot lately to.
Also new one today, "check guages"??
Was getting the lighting bolt and p0106 before doing injectors and pump.
Thanks for any help.
Diesel Filled Veins!
Check your battery connections, clamps and posts to ensure they are all clean and tight. If they are perhaps get both batteries load checked, if one is bad replace both. Bad battery connections and/or bad batteries can cause code soup for no reason.
:agree2: A bad battery can cause the most bizarre problems. The P0106 is very likely a sooted up MAP sensor. Very easy to clean. Much has been written on this forum about the procedure. I consider it part of the regular maintenance on my truck.
1 - 3 of 3 Posts
