on my way home today i got these codes. forgive my ignorance please.
P2000-nox Adsorber Efficiency Below Threshold - Bank 1
P0513-invalid Skim Key
anybody know what thats about. i plan on taking it to the dealer tomorrow should i take off my AFE intake?
like i said forgive my ignorance and please help
thanks, J-Mo
Discussion Starter · #2 ·
bump....anyone??
I've had them both. Pretty sure you can clear the 0513 and it won't come back. P2000 is probably the oxygen sensor, most likely covered with soot. It doesn't hurt anything in the short run. I had my oxygen sensor replaced about 3 weeks ago and it hasn't come back yet. There's a rumor that Dodge is going to have an oxygen sensor with a revised design or shielded in some way later this month. Supposed to be a permanent fix, says the rumor.
thanks for the help... could they tell me this is because of my AFE intake? should i take it off before i go back to the dealer?
J-Mo
thanks, J-Mo
I would take your intake off.
Have you had the g30 recall?
If not that is the P2000 code an they will replace o2 controler If you dont have the AX for 07 and AF for 08 I would ask them to due that too.
