1 - 3 of 3 Posts
well like the title says, what are the symptoms of a clutch slipping? the reason i ask this is ive never really felt a clutch slipping so i dont know if thats what my problem is or not. i recently put my chip back on my truck. its a van aaken. it came with the truck, it just plugs straight into the vp and i have no idea how much power it adds to the truck. after i put it on i can feel my truck start bucking when it gets under a load like driving up a hill. its almost like a slight miss or jerking feeling. my fuel pressure never drops below 14psi so i dont think it has anything to do with that but i'm not sure yet. any ideas?
On call 24/7
Your rpm's will jump when you get into the throttle and the truck wont go any faster untill the clutch catches and if you do it long enough it will smell burnt. The jerking may be the box if you letting the truck chug down a little.
ok so hopefully its just the box cause my rpms dont change at all. im going to take it off tomorrow and see if it stops
1 - 3 of 3 Posts
