Where did you get the master and slave from?? I didn't know that there was any bleeding involved. I installed the upgraded hydraulics from South Bend several years ago and there was no bleeding involved.No body?????
I'll be working on it next weekend if anyone wants to help. Gotta get the clutch master and slave changed out, pull the headache rack and figure out what-all is gonna be involved in taking the 6" lift of of it....... Anyone stopping by to help will be fed smoked ribs or pulled pork.... ain't decided yet.
Mike
Got them at RockAuto.com, Raybestos brand. One of the posts in the tech sections mentioned bleeding the system was a PITA and problematic if not done correctly.
I just finished bleeding my slave 98 3500 5.9 5 speed. I took the slave went by auto parts store bought the smallest bleeding valve they had the valve and stim must be tapered. Then went to garys and son in Humble texas had them drill and tap a hole in the end of the slave install the bleeder valve and there you are a factor made bleeding on the slave. My cell phone is 832-331-9353 call me if you have a question I will take pic's and send them to you.Where did you get the master and slave from?? I didn't know that there was any bleeding involved. I installed the upgraded hydraulics from South Bend several years ago and there was no bleeding involved.
Yes it can be done I just had a bleed valve installed on my slave call me i will give you details it not a big problem but should have been done by the factoryAnyone have experience bleeding a new clutch master and slave cylinder? Gonna try and start it some evening this week...... I hope.
you may want to put a bleeder on it first see my pic it works for meAnyone have experience bleeding a new clutch master and slave cylinder? Gonna try and start it some evening this week...... I hope.
