I am looking for information on clutches. I'm fairly new to understanding them.
How close do you have to be to the right hp numbers? How do you know when the one you have is going out?
PO said he replaced the clutch a year before I bought the truck with a stock replacement. The clutch has always engaged when the pedal is almost all the way out, but as i read more about clutches, i understand that that is a sign of them going out. I have added a quad xzt+ and 100 hp injectors so am I overdoing it on a stock replacement? It only slips when I take off in second.
I also plan to add plenty of HP in the next couple of years - edge comp, turbo (probably twins) - so I know I will have to replace the clutch to do that. I will be using the truck as a DD but I also tow 4-6 days a week, and I'd like to be around 600hp. Is it possible to do all off the things that I want to do? I want HP, reliable towing capabilities, and a clutch easy enough for my wife to use. How soon should I replace my current clutch, and if I need to do it ASAP, I may as well add the power now and do it correctly once. I'm not opposed to spending the money needed to do it right (dual disk, upgraded hydros) but only if I need to.
Thanks for your help, my searches didn't give the answers I'm looking for.
