1 - 13 of 13 Posts
My truck isnt movein period! The pedal is a little harder to push in but the whole truck is like its stuck in neutral? i can change gears with out even pushin the clutch in... they dont grind or nothin... like the cluch is stuck???? any ideas of what it is? hopefully its just the clutch gone....
Will It Role In Gear Clutch Released?
Sounds like the clutch is gone and not transfering any power to the transmision. I would try removing the slave cylinder from the trans, ( DO NOT PUSH IN THE CLUTCH ) and the see if it will grind a gear if it does it might be the slave cylinder stuck holding the clutch in.
yes. it rolles as if its in neutral with the clutch out and in gear
input shaft
Dropped the trans and there wasn't a bit of clutch left... That was the pob!
o trust so did i. it was loud. lol
what's a new heavy duty clutch for these run $$$?
bout 2g's for a good one. dd 3850#
wow. I put a heavy duty marlin crawler clutch set up in my yota. Parts were under $300. I knew this one would be more, but wow.
Well Thats W/ Hydro's Too, And If You Have A 4500 You Ll Need The 1 3/8ths Input And Add 500 For That.
And That Crawler Dont Weight 7000# + With 900 Ft Lbs Of Torque Either.
1 - 13 of 13 Posts
