07 5.9 manual stock anyone have problems with the clutch fan ? Im hearing a noise and when fan kicks in truck jerks . Any ideas ? Thanks
It’s not the AC clutch you’re feeling is it? I’ve never heard my fan in the 4 years I’ve owned this truck.
Its not the A/C clutch.I can hear the fan when it locks up..I think its goin out
Trying to learn
are you saying the truck actually moves/jerks when this happens?
When the fan clutch goes into lock-up it should roar.
what is your coolant temp at when this happens?
Reactions: rghavana
The fan clutch puts an extra load on the engine when it locks up and makes an obvious roaring sound, but I've never heard of one making the truck jerk or move. The field service manual has diagnostics for the fan clutch that can help you determine if it is bad. You can also remove the serpentine belt and spin all the bearings that ride on the belt. Repair/replace any part with a rough or noisy bearing. I wouldn't dismiss the AC clutch without further diagnostics as the fan clutch and AC work together (ECM commands fan clutch to lock up when AC is on).
I recently replaced my fan clutch. Here's a thread that I started when I was going through the process.
https://www.cumminsforum.com/forum/3rd-gen-powertrain/2507211-fan-clutch-not-working.html
Only does it when im towing my trailer.Temp is just over 200..Diesel mechanic friend said sometimes they go bad lock up all at once..
