I need to adjust my clutch and not sure how with the hydraulic system. My clutch engages and disengages at the top of the pedal. Any help would be great.
No adjustment on these trucks that I know of???
No adjustments.
mine is a '92 and it's hydraulic and like others they self adjust after a while.
'92 w250 clubcab, 5speed,ic, fuel screw played with, 4" back strait pipe with jacob exaust brake, hx35 turbo and heat coils gutted.
thanks for the reply's everyone. My dad thinks there is a shaft at the pedal that can be moved. I will give a look and post what I find. Maybe I need a new hydraulic unit.
If it engages at the top of pedal travel, your clutch disc could be worn, but it's probably just the nature of the beast. When mine had less wear on the pedal linkages, it engaged higher. Beats throwing the pedal to the floor and still not stopping due to linkage wear.
DP
DP
That's for sure dpuckett.
the clutch is new I just put it in last weekend. that is where the clutch engaged before the new disc so I was hoping the new one would cure it. I guess not.
