1 - 4 of 4 Posts
This 98 2500 24v alternator not charging and the only gage in the cluster that works is the tach.Where should I start looking?
Mopar1973Man.Com
Check for error codes...
OBD II Error Codes
I bet money you find a crankshaft sensor problem... Being the crank sensor controls the alternator...
Mopar1973Man.Com
does'nt the crank sensor also control the tach?the only gage working.
Opps... :doh:
But still check the codes...
As for the gauge cluster that is supplied from the PCM so there could be a error code about the CCD network. As for testing the cluster try this...
Cluster Testing
1 - 4 of 4 Posts
