So now my speedometer drops to zero periodically(sensor is new) and at other times all gauges(exc. tach) drop to zero and there is a chime as well the odo flashes.Also no check gauges light comes on Any ideas where to start? Thanks guys!
Similar Problem
I had a very similar problem with my 98 12V. the dealers techs couldn't figure it out. Turned out to be a faulty ESS (Engine Speed Sensor). have had to replace it a 2nd time as well. Hope this helps.
Does your Odometer show a "NO BUS" message?
My cluster did the same thing and it was a loose bolt in the engine compartment fuse box where the main cluster attaches. Will see if I can find the photos I uploaded.
Arcwelder
Negative on the "no bus" also no check gauges prompt I'm going to change the abs sensor on warranty to eliminate that possiblilty as speedo dies alone more often than other gauges no codes to be found either very much appreciate the help
