i second that notion :agree2:if you are going to be putting alot on that 3250 and sled pulling i would recommend going up to a 3650, but for just drag racing they do shift better
What was you thinking when you bought a heavy duty stock clutch and then say drag racing clutches are rated to hold power after engagement you can't take a organic clutch and boost launch it that clutch is good for what it was designed for and if it was properly installed now you want a dual disc wow what a jump that isThanks everyone for the input, i dont do any sled pulling and just a little drag racing and messing around i just wanted somthing to hold the power. I have a valair 400hp rated clucth and can you say JUNK!!! i dont recomend any one buying one unless your stock..
