make sure the lift pump is an aftermarket high performance lift pump.
then get a fuel pressure gauge. you always want your fuel pressure to be between 10 and 20psi. even under wide open throttle. if it gets out of that range, it becomes dangerous for your injection pump.
after you get those, I'd go with an adrenaline with pulse. gives you both bottom end power (like a smarty) and top end power (like an edge or tst) and you can update and download new tunes via USB.
it also has custom tuning for when you are ready to tweak your tunes to compliment your trucks setup and your needs.
adrenaline with pulse will show you gauge readings on the pulse monitor, but if you go with anything else besides adr/pulse or edge juice with attitude, you will need to buy gauges to monitor boost and EGT. (trans temp too if you were an auto) those monitors can do fuel pressure too, but I would more trust a mechanical fuel pressure gauge than an electronic one...
as for clutch, adrenaline is capable of slipping a brand new stock clutch, so either keep the power backed off a bit, or upgrade the clutch to a south bend or valair clutch rated to handle more power.
a boost elbow will also help you get more than 26psi out of your stock turbo.
retorque of the head bolts to 125lbs/ft will ensure you don't pop the head gasket, and you might want to do the 5th gear nut upgrade if/when you have your transmission out, to prevent 5th gear from failing.
