I know Diesel Manor has them. That is where I got mine. I believe GDP also has them.Where do you get the tapped banjo bolt. I am going to get the isspro gauge set up and it comes as package but I don't think it has that bolt.
If you just want to check the fuel psi. If you have a local diesel shop that does fuel systems. They should have a OBD scanner (or similiar) to h/u to check the idle and wot pressure.I want to hook up a fuel pressure gauge to my truck and see what the lift pump is pushing out for PSI. Is there a shrader Valve somewhere I can check it off of? Or were is the best place to check it from?
