2007.5 MEGA CAB
I have a 2007 dodge 6.7 Cummins. A few weeks back I replaced the alternator and charged both batteries while they were disconnected. After I hooked everything back up the truck didn’t want to start just clicked. I disconnected all the batteries again cleaned everything really good and reconnected making sure everything was tight. Truck started with no problems except the check gauges light stays on. My volt meter sits in the middle at 14 truck runs fine. Anyone run into a similar problem??
it might be something simple as an electrical hick up when everything was being reconnected, i would clear the code if there is one and just go from there, my guess is nothing will pop up again
I check again this morning. P063C
so i just did a search and found a super long reply from a guy that listed everything that the P063C code could be, figured it was easier just to copy and paste you the link… P063C Code?
