where is the cheapest place to get;
baldwin pf7977 someone said on this site they get them for $7.00?
the new cummins Venturi Combo Lube Filtration
***UPDATE***
Venturi Combo Lube Filter # is LF9028
Fleetguard stated that the filter will filter 30Microns @ 98.7% and 5 Microns @ 95%. Fleetguard also stated that the oil change interval is "5000 miles past manufactured recommended change, then send in oil sample and if the sample is good then you can go for another 5000 miles. The tech also said that its is a dual part filter and that while the full flow filters @ 30 microns, 12% of the oil is separated and filtered @ 5 microns. This sounds to like the Amsoil style setup but with just one screw on filter and a different change interval. A lot less work.
If I am correct this will extend oil change intervals and filter down to a whopping (30 microns then to ) 5 microns. This filter could give you and extra 10,000 miles between filter/oil changes (I change my filter @ 5000 and my oil @ 10,000miles). This would greatly reduce my costs on filters and oil, mainly oil. While still getting 5 micron filtering.
arty018:****UPDATED AGAIN****:thumbsup:
Baldwin BD7317 Dual-Flow Oil Filter Baldwin BD7317 Dual-Flow Oil Filter Venturi replacement/cross reference filter
http://www.baldwinfilter.com/literat...ts/form331.pdf
When I looked up the cross reference this what I found. Baldwin stated that thier filter the BD7317 was a dual pass venturi that is rated @ 20 microns full flow and 10% was filtered @ 5 microns . The tech could not give any more info than that (as far as change intervals). This filter is a direct replacement for the fleetguard LF9028 and is much cheaper.
After calling Baldwin back and talking to an engineer named "Randy" he stated that the filter has the same filter components as fleetguard and if Fleet guard LF9028 is an extended service filter then the Baldwin BD7317 would have the same service life if not better, it is just not printed/marketed as such by Baldwin. In my research I see that they also use the filter for hydraulic fluid filtering and maybe that has something to do with lack of "extended service interval" info.:drool2:
***UPDATE***
