1 - 4 of 4 Posts
so anyone seeing a problem with buying a nosal and hooking you wiper pump to the intake then you could hold it when your getting on it and use it when you want. i understand it would work off boost but should cool egts if you need to quick right???????
will not work. no where near the pressure that you would need to get any type of spray pattern.
TECH SPECIALIST
you can not compress water... it NEEDS TO BE IN the finest mist possible... at least 150 pump is needed... and a check valve... if u do ur CHEAP way.. you will prob hydro lock your engine
yea i guess you are right back to thedrawing board
1 - 4 of 4 Posts
