1 - 20 of 61 Posts
i just wanted to let everyone know about a cheap alternative for a grid heater delete it is available at any cummins dealer the part number is 3922484 it costs about 33 dollars
Banned
$33 to get rid of a grid heater? Its late so my brain isn't totally working, but wouldn't the truck cease to run without the grid heater? isn't it a good thing?
Banned
Wow...really? The good ole Cummins dealer never ceases to amaze me! Wish I would've known that before! Did you pick one up? Pics???
This might sound stupid, but how much difference does it make with the delete in and would it be a bennificial for me to do it?
It only improves your economy if you don't have to warm your truck up. If you live in a colder climate and have to start your truck below 40 degrees your truck will not start as well or warm up near as efficiently as it would with the grid heater installed so therefore would not improve your fuel economy.
I have seen this delete and it seems very popular, but my question is why? I use my truck as a truck. I do have an edge juice/attitude and its a very nice improvement...but why sacrifice cold start performance for a few horsepower if you aren't using the truck for sled pulls or racing? It probably only worth 10hp so i can't see why it would be a good idea for most of us.
I have problems with my electronics functioning properly while the grid heater is on, it drains my voltage down to about 11V. However in Tucson AZ I think I would be okay without it. I'm going to check this out for sure.
I haven't took mine off to look at it but I have a machine shop and i thing I can do this delete for $free.99 with my milling machine and just take the bars out of the existing spacer block.
Banned
i tried to find this on the net and came up with squat.
anybody have a link that shows the delete ?
I'd assume it looks just like the GH, only with the inside gutted...maybe smoothed out a bit too. Makes sense that Cummins would have it...
You can gut your stocker but if you ever need it again, it'll be mroe expensive to replace it then to just get a delete.
are we sayin its worth it...not for 6 hp. my truck dont run that many rpms often enuff to make it worth it to me
SootCloudMaker3
I will be deleting my grid heater when i finially get my intake manifold.
hydraulic lifter crew
i agree, rarely do i roll my truck past 2k unless im coming home from a bar and hot roddin it on the toll way.
the article didnt say how they closed the loop on the electronics of the gh though, and i didnt see anything on the aftermarket one to take care if it either.
Tech Specialist
I'm running a grid heater delete. It's a pretty blue block of aluminum. Other than that, no difference in temps, spool up, power, MPG, etc.
why then..do i need it
1 - 20 of 61 Posts
