99 dodge 2500 cummins "sport" 4wd auto.
168K, completely stock besides what appears to be an in-tank transfer pump, and an apps sensor ground wire fix for the torque converter lockup issue. and a timbo apps
Fired the truck up one morning to a dead pedal.
no codes, but no pedal. Issue continued for a few days, only happened on startup, only happened sometimes. If the truck started and ran, it would run fine all day.
Got the timbo apps, installed, same issue until I did the battery disconnect/ apps reset.
got my throttle back and haven't had that issue again, but upon getting my throttle back I also got a check gauges light that lingered for about a minute and a check engine light as well.
next day scanned a P1694 "No BUS Message Received from ECM Mod"
and today I had a hard start and now got a P0217 "Decreased Eng Perf due to Eng Overheat Condition" on startup, my truck never got hot.
I've cleared the codes, and the p1694 came back in the middle of a smog check, when the guy shut it off and started it back up, failing my trucks smog check,
the codes only re-appear during start up and are more often then not accompanied by 10-15 seconds of a check gauges light. All gauges display correct, in spec readings though.
From my research on the forums I have been lead to look for electrical connection issues. I tested the batteries and both test okay.
Ohm test on the terminals shows no crazy resistance issues.
figure the next step is to clean and check the connections for the ecm in the fuse box, and on the ecm itself.
Once the truck is fired up and running, I have never had any performance issues, no loss of power or throttle, gauges or lights. I hope this isn't a vp problem. :S:
